Possible fuel leak.... 3.4 engine...
Old Mar 3, 2013 | 01:40 PM
MJClemm's Avatar
Default Possible fuel leak.... 3.4 engine...
Hello guys, have a question about a fuel leak on my daughters car.....
First off, it cranks a little bit longer than normal to start in the morning.
2nd, a strong smell of fuel outside the car,
3rd, when driving the car, you can not smell the fuel inside of the car
4th after parking the car, you can smell gas agin...
The things I have done, .....replaced the gas cap, checked under the car for fuel, nothing under the car. Replaced the fuel vapor canister by the gas tank last summer, didn't have any issues till last week. Confusing ?
I was thinking possible the fuel filter? (But thought I'd see gas dripping)
Fuel regulator (how do you check them if they are leaking internally?)
Fuel injector (hard to see if its leaking)
Fuel rail (no visible leaks)
Any help would be GREAT , and needed ASAP to avoid a Blaze.... Thanks ain't...mjclemm...
Old Mar 3, 2013 | 05:18 PM
Doing a visual inspect on the lines and filter are the best thoughts I have. A friend of mine had a fuel line leak that we never saw it drip, but the line was ALWAYS wet and you could smell it.
Best of luck finding the source.
Old Mar 3, 2013 | 07:24 PM
tps221's Avatar
get it to your mechanic asap
Old Mar 4, 2013 | 02:13 PM
MJClemm's Avatar
Thanks guys.. Will do both... A quick look, then off to the garage... Thanks again...mjclemm...
MonteSquarlo
Dec 16, 2012 06:18 PM
ang913
May 22, 2012 08:06 AM
augi
Jan 25, 2011 10:03 AM
87fastback
Mar 21, 2010 02:45 PM
jessymo
Feb 19, 2009 10:07 PM
