Engine heat on 2006 SS
Old Aug 6, 2007 | 02:52 PM
omb76's Avatar
Default Engine heat on 2006 SS
Hey guys, have any of you with the'06 or '07SS noticed a substantial amount of heat coming off the engine? I drive about 25 miles each way to work and when I park it after the drivethe front end of the car (hood & fenders)is actually hot and yesterday when I went to open the hood, the release latch just about burned me. The temp guage reads normal, but just seems like a lot of heat there. Is this normal onyours?
Old Aug 6, 2007 | 05:46 PM
04 Intimidator's Avatar
Default RE: Engine heat on 2006 SS
Never heard of a problem like that and there shouldn't be. That is a big safety issue. I would bring it back to the dealer if still under waranty.
Old Aug 8, 2007 | 07:46 AM
06MonteSS's Avatar
yes, there is a lot of heat generated under the hood... it's normal for our cars... it's all freakin' engine in there! LOL
I removed the plastic engine cover and the rear weather stripping at the base of the windshield so the heat has a way out from under the back of the hood...
Old Aug 14, 2007 | 09:36 PM
TheFullMonte's Avatar
i noticed that the 3rd day we had ours. way too hot imo!
Old Aug 15, 2007 | 06:47 AM
Laserblue06ss's Avatar
If I pull my car in the garage after driving it on a hot day the garage heats up like an oven.
Old Aug 15, 2007 | 07:14 AM
wiz kidd's Avatar
wow, must be an issue on the 06,07 models, because mine doesn't heat up, my truck used to be really bad....but i dont get anything off the monte barely
now you could invest in a universal electric fan under the hood...that may help things out if there's room for it...they usually run anywhere from 50-100 bucks...so not too bad
Old Aug 15, 2007 | 03:27 PM
Install side louvers and hood scoop.
Old Aug 15, 2007 | 03:41 PM
wiz kidd's Avatar
lol...those little stick on ones!!! lol
Old Aug 15, 2007 | 07:23 PM
boutsix of em should do it...hahaha
eastnjman
Nov 15, 2011 10:07 PM
06LT
Mar 22, 2011 09:39 PM
red04montels
19
Sep 30, 2009 08:33 AM
Kruelty
Nov 12, 2007 07:43 AM
skimmy
Jan 13, 2007 02:14 AM
