Electrical help
Old May 3, 2022 | 08:29 PM
Wildfan's Avatar
Default Electrical help
Having some issues. 05 monte. What I notice, turn signal hazzard switch buzzes with no lights or flashing. And the airbag light is on. It will stay that way until I drive a couple miles, at which time the gauges go off, and on quickly, and everything works fine. I tested the fuses when it is malfunctioning and they have 6 volts. If I put a 12volt wire on them, the airbag light goes away, and blinkers work fine. This is in the fuse box, inside, drivers side. Other fuses in that box have 12 volts. Anyone have any thoughts for me? I would take a look inside the fuse box but cant find out how to remove to access the wires.
Old May 3, 2022 | 09:43 PM
Something is causing a large drain on that fuse block. Anything aftermarket in the car? Perhaps something is charging up and messing with that circuit to the fuse box.
Old May 4, 2022 | 07:41 AM
Wildfan's Avatar
nothing aftermarket. Very puzzling. My only other thought is to find a good wire and hook up to those slots with inline fuses.
Old May 4, 2022 | 08:57 PM
cjohns238's Avatar
Default DRL wiring change
So I have a crazy idea and I have been searching for a way to convert the DRL from the headlights to the fog lights.
2001 SS Monte Carlo
Is this possible and still be able to use the fog lights at night??
It would definitely make the monte stand out from the rest.😁
Old May 5, 2022 | 07:48 AM
2001 SS Monte Carlo
I suggest you start a new thread as this is not related to this topic.
Rondelle15
May 14, 2021 09:04 PM
zzapultimate
Nov 23, 2012 06:31 AM
MySS
Aug 10, 2012 08:58 AM
Larrysmonte
Mar 7, 2012 09:50 PM
plugitin
Oct 16, 2011 10:35 PM
