Info: How many ohms should I have?
Old Apr 30, 2022 | 09:29 PM
Boyd83's Avatar
Default How many ohms should I have?
I just bought an 01 and the previous owner ran wire from the driver fuse panel to the radiator fans. The car obviously had cooling issues such as temp gage not working, but from what I can tell it hasn't been over heating since I've had it.
I ordered new hoses, t stat, and temp sensor. I found the original wires that were cut from the connectors and rewired them. With everything thing back in working ordered, my investigation begins. I ohmed out the wires and relays one by one. I have 1 ohm on 3 out of 4 wires. I'm not an electrician but that seems really low to me. So my final conclusion is no continuity. I plan to run new wires from the back of the relay box to the fans. After this I'm going back to hardwire like it was when I got it
Old May 1, 2022 | 12:03 PM
Unfortunately its not clear enough what 2 places you're checking between for us to provide input on the result you got.
Are you trying to check resistance from one end of the wire to the other (/ continuity check)? Are you checking ground path?
1 ohm might seem low, but it sounds high if you're just checking one end of a wire to another. If I remember back to the few EE classes I took, 16 gauge copper wire is like 4 ohms per 1000 ft. A 20 foot or less run (ie pretty much any length you'd see in a car) shouldn't even be a tenth of an ohm if its just checking one end of a wire to the other.
Lack of continuity would be no reading at all (same as holding the probes up in the air). The one caution with checking continuity is that it only confirms theres at least a single strand of the wire remaining. It can't tell if say a mouse chewed through 90% of the wire or if the insulation is gone and it occasionally shorts out in a certain condition (ie accelerating/ turning / etc).
Old May 1, 2022 | 08:19 PM
Boyd83's Avatar
Default Not the news I wanted to hear
I was testing one end of the wire to the other. I also checked to see if one was fused with another. I had subohms on 3 of the 4. If what you're saying is true. I have no more ideas, or solutions.
Thanks for the info
Old May 1, 2022 | 08:24 PM
So you're saying you got a reading on 3 of the 4. If thats the case, doesn't that mean you've found a problem (that the 4th wire should have continuity, but doesn't - assuming you're reading the wiring diagram correct and its supposed to be an uninterrupted continuous piece of wire)?
Old May 2, 2022 | 11:17 AM
Boyd83's Avatar
I have sub ohms on 3 out of 4. The 4th wad 1 ohm or better
Old May 2, 2022 | 06:56 PM
Thats odd - are they all about the same gauge and run length? Over 1 ohm is pretty suspicious if they're all basically the same wire type / run. Is there any corrosion you can see in the connector ends?
Have you identified what the 4 wires do and checked to see if that output was present on both the input and output side of that wire run. Or were all 4 not providing the expected output (ie 12v, ground, signal, whatever they were supposed to have)?
Old May 5, 2022 | 09:21 PM
Boyd83's Avatar
Update:
I got a piece of test wire that measured out to be 8 ohms.
I did locate a questionable ground and made a repair. Retested factory wire from the relay box to the fans. Also between 8-5 ohms, so I did not run new wire. After a coolant flush and new sensors I'm pleased to say that fans are working properly and was able to remove someone's ummmm, mess.
Coolant system is closed and moving forward to vacuum leaks. Thanks for everyone's help and suggestions.
Never thought this car would capture me
ohara
May 2, 2022 11:22 AM
catchk9
Apr 15, 2011 07:03 PM
PUNK LIFE
Jul 30, 2010 02:27 PM
smolek37k
Nov 5, 2008 02:13 PM
smolek37k
Nov 1, 2006 07:11 PM
