6th Gen ('00-'05): drivabilty issues
Old May 7, 2014 | 12:29 PM
eiddo's Avatar
Default drivabilty issues
hi,
I have a 2001 Monte Carlo SS. Last week I noticed some idle issues from cold start, engine would hunt a little for a few seconds then idle OK. Monday car nearly stalled on the way home from work. Engine idled very rough, barely made it to the shoulder of the freeway. Had car towed home, Pulled codes P0420, P0102, P0131, changed Idle Air Control Valve, P0420 ( EGR valve replaced 2yrs ago) code went away. Car started and idled OK. 5 minutes later restarted car very rough idle and stall. I let car sit for 3 hour tried again car started and idle fine. Tuesday I drove to work and home and several other places with no issues. Went out an hour later car started and stalled within seconds. From posts I have read on MCF sounds like it could be the mass airflow sensor? If it is mass airflow sensor should i just replace or try cleaning? Any help is greatly appreciated, took off work today to try and resolve this issue. Thanks in advance.
Old May 7, 2014 | 12:34 PM
nitehawkjcb's Avatar
Sounds like the MAF is acting up, try cleaning it first.
Old May 7, 2014 | 02:19 PM
eiddo's Avatar
I disconnected (electrically) mass airflow sensor, engine started and ran without stalling.
I cleaned mass airflow sensor, same issue, engine starts the stalls. Should I replace MAF sensor?
Old May 7, 2014 | 02:25 PM
That's what it sounds like to me.
Old May 7, 2014 | 03:05 PM
PacerSS's Avatar
What year is yours? I might have a MAF laying around
Old May 7, 2014 | 04:50 PM
eiddo's Avatar
2001 SS
I looked at the MAF one more time. Female employee at Autozone noticed a huge chunk of dirt on the sensor. She told me to gently scrape it clean and replace air filter. I did, put it back in car reconnected it and engine started, idled and ran with MAF connected. I drove around a few miles no issues. I think I'm good to go.
Old Jan 4, 2015 | 11:37 AM
avendo's Avatar
not sure whats going on with mine,got the p0102 code today with the p0171 lean bank 1,been getting the lean code for a little while...
86montecarloooSS
Aug 16, 2006 03:50 PM
mayerichm
Mar 3, 2006 11:16 AM
jsteezy129
Nov 15, 2005 10:47 PM
jsteezy129
Nov 15, 2005 10:14 PM
GTown
Nov 11, 2005 11:27 PM
