6th Gen ('00-'05): No crank starting procedure
Old Jan 3, 2015 | 12:23 PM
panpan's Avatar
Default No crank starting procedure
Hi guys,
Last year my wife's 2002 MC had that problem that several MCs have: turning the key in the ignition and nothing happens. She would wait 20-30 minutes and eventually it would start.
I found on this forum a procedure to start when this happens. It was a really simple procedure involving flashing the lights three times and some other steps I don't remember. It took less than a minute. I printed it and she kept it in the glove box. She used it several times and it worked. But a few months ago I replace the ignition on her car and it doesn't happen anymore. So she trew the paper away.
Now it happens with my other MC and I would like to retrieve that procedure. I have search for it using every keyword I can think of: ignition - won't start - passlock - passkey - no crank - etc but can't find it.
If anyone knows that procedure or can help me find that tread, I would greatly appreciate it.
Thanks
Old Jan 3, 2015 | 11:36 PM
Under ignition relearn:
This is the page I found!
Monte Carlo Forum - Monte Carlo Enthusiast Forums - Search Results
Hope this helps!
Old Jan 4, 2015 | 01:00 PM
panpan's Avatar
Hope this helps!
Thank you STUMPMI ! You pointed me in the right direction. It was not ignition relearn, it was ignition reset. I should have found it with ignition alone, but I guess I missed it because too many treads were found.
https://montecarloforum.com/forum/mo...-system-18529/
This method worked on my wife's 2002 and on a 2000 that didn't crank at a used car dealer. I was able to negotiate a 750$ reduction because it didn't start
Thanks again
Old Jan 4, 2015 | 07:34 PM
Your quite welcome!
Were here to help!
Glad to know you have it fixed!
RickCoMatic
FWD Tech Guides '95-'07
31
Jun 14, 2024 05:29 PM
Absolutpolack
Dec 31, 2009 06:55 AM
knightfan26917
Jul 24, 2009 01:06 AM
knightfan26917
Mar 26, 2009 09:51 PM
Birge
Dec 30, 2004 03:09 PM
