Cranking problem
Old Dec 31, 2018 | 10:22 AM
Larryj558's Avatar
Default Cranking problem
changed switch and cylinder now when I turn to crank nothing everything on inside works and can hear fuel pump but when try to crank nothing pulled crank relay under hood jumped contact car started ran a few seconds then shut off need help 2002 MCSS
Old Jan 1, 2019 | 08:32 AM
Jeffs02rwdSS's Avatar
Since you swapped the key out you will need to do a relearn of the security system.The information on the procedure should have been included with the key and switch. Otherwise you can do a search on the forums as its posted quite a few times in here. Good luck
Larryj558
MCF Website Problems & Issues
Dec 30, 2018 05:56 PM
Dirtybyrd417SS
Apr 28, 2017 09:20 PM
Z28rob18
May 20, 2016 05:33 PM
lostcausenjtown
Jan 8, 2011 12:27 AM
jankie36
Jun 29, 2010 09:01 AM
