6th Gen ('00-'05): Engine,transmission and ignition swap. No crank.
Old Apr 28, 2017 | 08:47 PM
Dirtybyrd417SS's Avatar
Default Engine,transmission and ignition swap. No crank.
I did complete engine and transmission swap, along with ignition switch. When I turn key to on position everything comes on including the fuel pump. But will not crank over. Also tried resetting the security passlock. No luck. Any ideas?
Old Apr 28, 2017 | 09:20 PM
BlvckSuperCharged's Avatar
did you ever solve This ? I have the same problem
