Cranking problem
changed switch and cylinder now when I turn to crank nothing everything on inside works and can hear fuel pump but when try to crank nothing pulled crank relay under hood jumped contact car started ran a few seconds then shut off need help 2002 MCSS |
Since you swapped the key out you will need to do a relearn of the security system.The information on the procedure should have been included with the key and switch. Otherwise you can do a search on the forums as its posted quite a few times in here. Good luck
