Couple of issues
Old May 25, 2009 | 10:55 PM
Carminered00's Avatar
Default Couple of issues
I have a 2000 Monte carlo LS 3.4--150k miles
I have 2 issues
1. My blinkers and Hazards stopped working, I can kind of beat on the dash above it and it'll work for about 3 seconds then stop. Could it be a bad ground or loose wire? How do I get to it without tearing the dash apart?
2. When I first start the car it has a sort of tapping oily sound then after about a min or 2 it goes away, or sometimes when you drive a little then stop it goes away. I'm using a crappy Fram oil filter and some castrol non synthetic. It sounds like it's coming from the top of the engine.
Old May 26, 2009 | 07:47 AM
baja216's Avatar
I have 2 issues
If I'm not mistaken the emergency flasher switch controls the turn signals and the flashers. I had the same problem with my '02 Impala. I replaced the unit and had no further troubles. On the Impala forum they had all the instructions on removing the dash cover. I'm new over here so I haven't found anything like that yet for the Monte's
Old Jun 2, 2009 | 01:22 AM
Weber's Monte's Avatar
with the tappin olily sound is just the valves clicking my grand prix used to do that and my buddys truck does the same thing, i think its just a something a older motor tends to do.
Old Jun 2, 2009 | 06:26 PM
MAMONTE's Avatar
What oil weight are you using? Sounds to be like valve chatter....My newer monte does it sometimes too...Not a big deal. But being you only hear it at start up, MAYBE a lighter weight oil would help cure the problem a little. Like a 5w-30...and if you switched to 10w-40 due to the high milage on you car, maybe try a 5w-40, which you will only find in synthetic due to the large weight gap. Wal-Mart sells Shell Rotella-T synthetic 5w-40 for like 19 bucks a gallon. I use it in my really high milage truck (230K) and it works great!
Otherwise, I would not worry about it.
Old Jun 5, 2009 | 09:29 PM
cqdqd2's Avatar
I had a similar problem with my 04 SS. I had to replace the flasher module which is behind the hazard switch in the dash. I believe there wer 4 screws and a couple of clips hlding the dash on.
Cbriedis
Jul 26, 2014 01:38 AM
Sanjay Collins
Feb 11, 2013 10:12 PM
30thousandUP
Mar 27, 2012 02:01 AM
elprento
Jun 12, 2011 09:20 PM
montecarlo01ss
Jan 22, 2011 12:55 PM
