Couple of issues
I have a 2000 Monte carlo LS 3.4--150k miles
I have 2 issues 1. My blinkers and Hazards stopped working, I can kind of beat on the dash above it and it'll work for about 3 seconds then stop. Could it be a bad ground or loose wire? How do I get to it without tearing the dash apart? 2. When I first start the car it has a sort of tapping oily sound then after about a min or 2 it goes away, or sometimes when you drive a little then stop it goes away. I'm using a crappy Fram oil filter and some castrol non synthetic. It sounds like it's coming from the top of the engine. |
Originally Posted by Carminered00
(Post 132708)
I have 2 issues 1. My blinkers and Hazards stopped working, I can kind of beat on the dash above it and it'll work for about 3 seconds then stop. Could it be a bad ground or loose wire? How do I get to it without tearing the dash apart? |
with the tappin olily sound is just the valves clicking my grand prix used to do that and my buddys truck does the same thing, i think its just a something a older motor tends to do.
(Post 132708)
2. When I first start the car it has a sort of tapping oily sound then after about a min or 2 it goes away, or sometimes when you drive a little then stop it goes away. I'm using a crappy Fram oil filter and some castrol non synthetic. It sounds like it's coming from the top of the engine. Otherwise, I would not worry about it. |
I had a similar problem with my 04 SS. I had to replace the flasher module which is behind the hazard switch in the dash. I believe there wer 4 screws and a couple of clips hlding the dash on.
