Cost of new hubs install for an 06 SS?
Old Feb 4, 2011 | 10:37 AM
irulesoha's Avatar
Default Cost of new hubs install for an 06 SS?
I've seen that you can buy new hubs for about $60each for the front. I have some ABS and traction control issues and the mechanic at Goodyear says my bearings are going out.
So I need some new hubs.
How much does this typically cost? The dealer wants 250ish each, which seems high. What about at a local mechanic?
Old Feb 4, 2011 | 12:49 PM
jim1405's Avatar
Before you replace the hubs, what kind of ABS issues are you having? On my 2001 Monte I had the abs light on and a 'service traction control' message. A mechanic said it was likely the hubs but I did some digging on my own and found out the abs wiring harness to one wheel was bad. 35 dollars for the harness and an easy do it yourself fix.
Old Feb 4, 2011 | 01:34 PM
Jester_20's Avatar
I had a ABS problem on my 96 MC a LONG time ago. The dash light turned on and they quit working so i thought it was going to turn into a major problem. . . turned out to just be a fuse. lol good luck
Old Feb 8, 2011 | 03:37 PM
JerryD's Avatar
I would stay away from cheap hubs. Timken (IMO) makes the best hubs. The estimated labor time for doing both L & R front hubs on my '01 is 1.2 hours. So multiple the hourly rate, add the cost of the hubs and there you go. There is a TSB out on the '01 - '03 models for the harness, but it doesn't hurt to check on yours...
Old Feb 8, 2011 | 03:48 PM
I replaced the rear driver side on mine with a Timken bearing ($87 on amazon) and I paid a mechanic $60 to replace it at the place he runs/manages afterhours.......
Old Feb 9, 2011 | 08:49 AM
06MonteSS's Avatar
a few months back, I had to get new front wheel hubs (because bearings where shot), and new front axle assemblies (because cv joints were shot)... oh, and also needed a new intermediate steering shaft...
I've got 102,xxx miles on the car... and yes, I knew it needed all of this before I took it in to have it checked out, so none of it was a surprise to me when they told me...
cost me about $1,600 for the whole job... was about $5XX for the hubs... $6XX for the axle assemblies... I forget the cost of the intermediate steering shaft... and then my shops hourly rate of 118...
Old Feb 9, 2011 | 09:03 AM
If the dealer purchases the hubs it will be about $240 for each hub, and 1.5 hours of labor on top of that.
If you bring in the hubs, it will probably be 2 hours of labor lol
Chief Monte
Nov 4, 2014 01:50 PM
vikesfan
Mar 27, 2014 09:25 AM
Longislandmonte
Dec 23, 2013 01:00 PM
Overdose666
Oct 30, 2013 05:03 PM
izmouse
Mar 17, 2012 08:45 PM
