have problem with vehicle bulb checking while driving
Old Feb 8, 2011 | 11:55 AM
Carlo01SS's Avatar
Default have problem with vehicle bulb checking while driving
i recently bought a 2001 SS and while driving it will start bulb checking like the key has just been turned on i have replaced ign switch did not fix anything!! when it does this it does not have any running issue and the lights go right back off!! any idea???
Old Feb 8, 2011 | 12:52 PM
Having a hard time understanding the problem
Old Feb 8, 2011 | 01:14 PM
KJRich's Avatar
All the dash warning lights turn on and then off?
Old Feb 8, 2011 | 03:41 PM
Welcome to the site. Sounds like a weird problem. I'm sure one of our many members will have some ideas.
Old Feb 9, 2011 | 10:21 AM
Carlo01SS's Avatar
Default "Having a hard time understanding the problem"
when you start a vehicle or turn the key to the on position all the bulbs on your dash will flash on letting you know that the bulbs are not blown and are still working otherwise know as "bulb checking"...... the problem that i have is that my vehicle does this randomly when drive down the road... i have changed batt. check batt. cables, replaced ign switch.. and nothing seems to fix it.. i am sure it is going to be a module of some sort but which one? just thought someone else on here may have had the same problem???
Old Feb 9, 2011 | 03:09 PM
Paul1965's Avatar
Sounds like a ground/wiring/BCM issue. Going to be very tough to diagnose until you can get it to happen all the time.
rage772
Apr 24, 2008 02:45 PM
04 Intimidator
Jan 4, 2008 05:21 PM
BeachBumMike
Nov 27, 2007 11:34 AM
85MonteCarlo
Aug 8, 2007 05:12 PM
BeachBumMike
Jan 30, 2007 02:13 PM
