> Cooling Fan Problems - PLEASE HELP
I need assistance the car i have the cooling fans have been hard wired and po code 480 comes up on scanner how can I fix it. Thank You
Note 3.4L
Note 3.4L
Last edited by Space; Jul 7, 2012 at 04:01 PM. Reason: Put in need help with Cooling fans..Thank You!
Welcome to the Monte Carlo Forum..
I hope a member can post & help your with your Monte Carlo Problem...
Good Luck from `Space
Your Thread title was changed to help member's notice your thread & it was moved from New Members section to Tech..
A P0480 code = Cooling Fan I Control Circuit Malfunction. Since the fan(s) have been hardwired the PCM thinks their is a problem in the circuit (which technically there is) so it is setting the code. The only way you'll rid yourself of the code is to remove the hardwire circuit, then diagnose and correct whatever was wrong prior to the hardwire job.
cmw239
Sep 12, 2007 06:52 PM
