> Cooling Fan Problems - PLEASE HELP
Old Jul 7, 2012 | 02:44 PM
jcomes1's Avatar
Question > Cooling Fan Problems - PLEASE HELP
I need assistance the car i have the cooling fans have been hard wired and po code 480 comes up on scanner how can I fix it. Thank You
Note 3.4L
Last edited by Space; Jul 7, 2012 at 04:01 PM. Reason: Put in need help with Cooling fans..Thank You!
Old Jul 7, 2012 | 04:05 PM
Welcome to the Monte Carlo Forum..
Your Thread title was changed to help member's notice your thread & it was moved from New Members section to Tech..
I hope a member can post & help your with your Monte Carlo Problem...
Good Luck from `Space
Old Jul 7, 2012 | 07:17 PM
03SSLE's Avatar
A P0480 code = Cooling Fan I Control Circuit Malfunction. Since the fan(s) have been hardwired the PCM thinks their is a problem in the circuit (which technically there is) so it is setting the code. The only way you'll rid yourself of the code is to remove the hardwire circuit, then diagnose and correct whatever was wrong prior to the hardwire job.
Old Jul 7, 2012 | 08:08 PM
aussiek2000's Avatar
Rewire them the way they are supposed to be.
Old Jul 8, 2012 | 07:52 AM
DRuben's Avatar
I just finished tackling this problem. Just swap out the relay with a new one and it will work again. I tested my old relay and it was clicking but it was still bad so dont go off of that.
golf0982
Jun 4, 2009 06:29 PM
zk6216
Apr 13, 2008 02:49 PM
blazerman3
Mar 20, 2008 06:50 PM
seth_06
Dec 2, 2006 05:42 PM
