Cooling fan issues
Old Mar 16, 2008 | 11:36 AM
blazerman3's Avatar
Default Cooling fan issues
Ok,got a little problem with the `98. Noticed yesterday after the oil and filter change,fuel filter change and the K&N filter install that the cooling fans didn`t come on. I had road tested the car for about half hour and was idling in the driveway. Temp gauge went a little over half scale and no fans. The `97`s fans come on a lot sooner. Looking in the Haynes manual I`m thinking the trouble might be with those 2 fan relays. Any ideas? Thanks for the help.
Old Mar 16, 2008 | 01:35 PM
Default RE: Cooling fan issues
Hi Robert,
The best way I know to see `if the fans are kick'in in to
let & run with your AC on for approximately 15 minutes.
Your fans should kick `in & run.
If they don't I would check your relays.
We have several member's that are expert tech's
and hopefully they will read your post & reply.
Below is a previous thread on Cooling systems,
and electric fans. Hope it helps.
If yours isn't heating `up, I wouldn't worry about it,
but it always pays to keep an eye on gauges : )
Good Luck, `Space
[:-]Click on below link [:-]
Old Mar 16, 2008 | 03:14 PM
blazerman3's Avatar
Thanks Space....Gonna look into it some more....just hope it`s not the computer....lol
Old Mar 20, 2008 | 06:50 PM
blazerman3's Avatar
Problem solved...#1 Fan relay replaced and all is well....
sled head red
Aug 16, 2011 11:51 AM
mikepp1977
Oct 20, 2010 06:42 PM
zk6216
Apr 13, 2008 02:49 PM
seth_06
Dec 2, 2006 05:42 PM
