Cleaning 3.8 throttle body, need help!
Hello I have a 2003 monte ss with the 3.8 and am trying to remove the throttle body to clean it up. I have everything removed except for the bottom left bolt that holds the throttle body on, there is a bracket attached to the thermostat housing and there is not much room to fit even a wrench in there. Anyone have any tips? Thanks!
I was able to get the nuts with a socket driver and 10 MM socket with an extension. I assume you are referring to the front most nut on the bottom? I didn't find it difficult at all to get to. I used a 3 or 4 inch extension and a small ¼" driver. Worked perfectly.
I don't know how much room you have to work with but would something like this work? A retired mechanic neighbor introduced me to them and they've helped me deal with some pretty tight spaces.
Gear Wrench 5-Piece Open End Ratcheting Wrench Set - SAE 85596: You
It's a pain to get that bracket off. Fyi once off that bracket is not needed and don't need to be reinstalled. An open wrench should get it but it will take a while do to the cross over being there.
Faster
Oct 9, 2013 11:31 AM
Mattw.2009
Aug 1, 2010 01:27 PM
Steven73
Feb 18, 2010 04:30 PM
menaja19
Dec 10, 2007 07:57 AM
