Cleaning 3.8 throttle body, need help!
Old May 2, 2014 | 06:05 PM
blackss03's Avatar
Default Cleaning 3.8 throttle body, need help!
Hello I have a 2003 monte ss with the 3.8 and am trying to remove the throttle body to clean it up. I have everything removed except for the bottom left bolt that holds the throttle body on, there is a bracket attached to the thermostat housing and there is not much room to fit even a wrench in there. Anyone have any tips? Thanks!
Old May 3, 2014 | 08:54 AM
blackss03's Avatar
anyone?
Old May 3, 2014 | 09:11 AM
michelob's Avatar
I was able to get the nuts with a socket driver and 10 MM socket with an extension. I assume you are referring to the front most nut on the bottom? I didn't find it difficult at all to get to. I used a 3 or 4 inch extension and a small ¼" driver. Worked perfectly.
Old May 3, 2014 | 09:16 AM
DCMoose48's Avatar
I don't know how much room you have to work with but would something like this work? A retired mechanic neighbor introduced me to them and they've helped me deal with some pretty tight spaces.
Gear Wrench 5-Piece Open End Ratcheting Wrench Set - SAE 85596: You
Old May 3, 2014 | 05:24 PM
turbo monte's Avatar
It's a pain to get that bracket off. Fyi once off that bracket is not needed and don't need to be reinstalled. An open wrench should get it but it will take a while do to the cross over being there.
Old May 5, 2014 | 08:43 AM
x2, it takes a while to get it loose, but I did it with extensions and small hands lol
Don't add the bracket back when you put it back on
Old May 5, 2014 | 03:17 PM
michelob's Avatar
I think mine must be missing the bracket. LOL
Old May 7, 2014 | 05:15 PM
slowguy's Avatar
you can grind the bend off the bracket and reinstall it. It is a pain.
michelob
Mar 16, 2014 05:29 PM
Faster
Oct 9, 2013 11:31 AM
Mattw.2009
Aug 1, 2010 01:27 PM
Steven73
Feb 18, 2010 04:30 PM
menaja19
Dec 10, 2007 07:57 AM
