Solenoid Replacement?
Old Apr 25, 2014 | 04:47 PM
Jparks's Avatar
Question Solenoid Replacement?
Hey guys I searched everywhere in my past threads for a site someone left me about Solenoid replacement.
I keep getting a "Tighten Gas Cap" message on my 06 Monte SS.
What I was told before on the forum was it's as simple as replacing the solenoid... cost around $35.
Someone had posted a link a while back I think with a part link and How-to but for the life of me cannot find the thread.
If anyone could help or have any other fix suggestions that would be great!
Old Apr 25, 2014 | 06:28 PM
There's a bunch of evap codes. Many can be as simple a a loose gas cap, but if that's not it, GM normally directs you to perform a smoke test.
Apparently a purge cylinder is common for the P0455 code on some of these cars. Here's a write up from another forum on the subject:
HOW TO:Replacing Evaporative Emission Canister Vent Solenoid Valve (PO455 error)
Keep in mind, without doing a smoke test, you are throwing parts at the problem.
Old May 7, 2014 | 09:59 PM
gmjunkyard's Avatar
Default EVAP code discovery and FIX !
Go to post #'s 51 and 53 on the thread link below.
https://montecarloforum.com/forum/mo...e-23231/page6/.
This fixed my EVAP code problem permanently. I am beside myself with joy at getting this fking thing fixed. Hope it helps.
MM
tridski
Mar 4, 2010 04:41 PM
mekoku
Feb 27, 2010 10:05 PM
mrl390
May 31, 2008 11:48 AM
2003supersport
Apr 25, 2008 11:54 AM
2003supersport
Apr 25, 2008 12:50 AM
