Catalytic Converter Gaskets?
Old May 15, 2013 | 05:16 PM
Dylan313's Avatar
Default Catalytic Converter Gaskets?
I have a 2002 SS and I bought a direct fit downpipe with cat to swap in place of my clogged converter. However, I have never taken the exhaust apart on a Monte yet. I don't know what type of gasket I need for either end. I've seen a couple posts on cats but didnt see anything about the gaskets needed. Any help? I want to have all my stuff together before I climb underneath.
Also, what about replacement hardware?
Thanks guys
Old May 15, 2013 | 09:20 PM
When i swapped mine for a ZZP downpipe, I bought it with the gaskets. But here's a link to what I believe you need:
ZZPerformance - 2.5" Downpipe Gasket #ZZ-25DPGKT
and
ZZPerformance - 3800 Stock Manifold Gasket #ZZ-38MANGKT
You can contact ZZP to confirm, I am sure they would help you out. You can also check RockAuto.com, as they may have a slightly better price.
As for the hardware, I've never seen a bolt kit for it. I did mine on my '04 a couple years ago with about 55-60K on it. The hardware was a little rusty, but I re-used it all (looking back, I wish I would have gone to the parts store, matched it up, perhaps with some stainless steel).
Old May 15, 2013 | 09:27 PM
Dylan313's Avatar
That's what my plan is, just pull the hardware and try to match it up. I always prefer spending a couple dollars more for new hardware on things
Thanks for the links bro!
Old May 16, 2013 | 07:21 AM
03SSLE's Avatar
You could also pick the gaskets up at a local parts store and save yourself the time/money/shipping expense of getting them from ZZP.
Old May 16, 2013 | 11:32 AM
That makes too much sense lol!! Who goes to the brick-n-mortar stores anymore lol.
In all honesty, I am so adjusted to about 60-70% of my car parts are bought from RockAuto, I neglect to thing the obvious. In the case of these gaskets, the store is probably the cheapest and best bet. And if it's NOT the cheapest, it's probably not a big difference in price.
Furder2010
Apr 29, 2013 02:23 PM
Flying Miss Daisy
Dec 20, 2009 08:03 PM
04monte_Carlo
Oct 5, 2007 03:43 PM
Sackaphone
Apr 29, 2007 03:24 PM
mtwallet
Feb 25, 2007 09:16 PM
