Upstream O2 sensor replacement
Old Mar 29, 2013 | 12:18 PM
milrlyt's Avatar
Default Upstream O2 sensor replacement
Need a good brand and a how-to without the special socket for it. What other tool could I use to get it done? Been driving for about a week since the code was thrown so I need to do it asap.
Old Mar 29, 2013 | 01:15 PM
It's just a slotted socket that you need. Unless you hack off the wire first.
Old Mar 29, 2013 | 02:37 PM
milrlyt's Avatar
Cool... so it should be relatively easy. Thanks!
Old Mar 29, 2013 | 02:38 PM
It's not a bad job. Just warm up the engine a little bit, then rock it forward. D/C the battery.
Then you just have to unclip the wire and unscrew the sensor. Replace, reconnect the battery, and you're good to go
Old Mar 29, 2013 | 02:47 PM
milrlyt's Avatar
Why warm up the engine first? It's a tight fit b/w the engine and firewall... don't want it to be toasty.
Is Bosch a decent brand? And how long can I keep driving before it gets bad? I've put about 700 miles since the code first showed up. Couldn't get to an OBD II until today to check it out so I didn't know.
Old Mar 29, 2013 | 04:07 PM
turbo monte's Avatar
If you warm up the exhaust a bit it makes it easier to get loose. I would try and get it fixed asap before it trashes your cat converter.
Old Mar 29, 2013 | 04:10 PM
BOSCH is not good.
ACDELCO or DELPHI only
Old Mar 29, 2013 | 04:48 PM
milrlyt's Avatar
Ok. Thanks gents.
Old Mar 29, 2013 | 05:14 PM
milrlyt's Avatar
Should be OK for another 50 miles or so, right? I don't actually know how long I can run the car with an old O2 sensor and not damage anything. The sensor won't be here until Wednesday, I'm hoping I can hold out a little bit longer without damaging anything.
Old Mar 29, 2013 | 06:24 PM
The car is just running on old tables, doesn't really know the Air Fuel ratio, so you could be running rich.
That's never great. Hopefully not too much longer!
