Car sounds like it has a 2step?
Old Oct 16, 2009 | 01:40 PM
IcantDo55's Avatar
Originally Posted by Steven73
I would check coil Packs.... I had some what same issiu with onlyu 65 000kms I turned onto highway at like 3500rpm it it would hesitate kinda BUCK then shift. (this was only if i reached 3500/4000rpm... If i kept it under that would drive Fine and shift
Is there a way to "check" them or just replace them?
Old Oct 17, 2009 | 09:48 AM
Steven73's Avatar
Umm thier like 60 bucks each easy to change.. Umm just used a scanner is what i did. seen that thier ware 2 cylenders missing and both led to one coil pack. soo just changed them all. a mechanic will run scan.
Old Oct 20, 2009 | 02:21 PM
IcantDo55's Avatar
Changed coils and same problem.
Now what?
Old Oct 20, 2009 | 02:23 PM
What was your report back for the cat??
Curious if the MAF sensor could pull these faults too...
Old Oct 20, 2009 | 02:37 PM
monte07's Avatar
first what is all have you done. I mean as a check list on finding out what the problem could be. write down what you have done and the odveuse could appeare like the cat could be bad first i will replace that then if it did it again the maf is the culprit because didnt you say the monte 2000 had very little matenence done on it? the maf is the chapest to replace do that first then the cat if it did the same again
volsmokeater
Dec 5, 2010 01:43 PM
NYGiantsfan
Sep 9, 2010 05:43 PM
BLACK ATTACK
Jun 27, 2009 10:17 PM
motivation2k3
Aug 17, 2008 07:50 PM
