Car sounds like it has a 2step?
Old Oct 11, 2009 | 06:09 PM
IcantDo55's Avatar
Default Car sounds like it has a 2step?
Working on a friends 3.8L 2000 and it won't rev above 4K rpm sounds like its on a 2 step. On the road or in neutral no difference.
Car has 200K on it and little to no matience, and as far as I know its been like this for 10-20K miles.
There a common cause for this?
Car does have a CEL on but until I fix the cooling system problem in my other thread I can't bring it anywhere to get codes read.
Old Oct 11, 2009 | 10:12 PM
Budsjlm's Avatar
well in nuteral/park the comp limits it at 4 grand if i remember right... and if it does it in drive it may be in limp mod becuase of the problem mentioned in your other thread
Old Oct 11, 2009 | 10:37 PM
IcantDo55's Avatar
It will do it in neutral/park or on the road while driving. This sounds like an ignition miss and being the CEL is flashing confirms its missing.
Old Oct 12, 2009 | 09:49 AM
MAMONTE's Avatar
Ignition Coil maybe?
Old Oct 14, 2009 | 02:27 PM
IcantDo55's Avatar
So I have removed the upper intake and check it out, replaced gaskets and cleaked out EGR, replaced wires and plugs, removed and cleans the coils and module under them.
Than I cleared the codes and the car still does the same thing @ about 4K it just hits a wall and wont rev any higher, while driving or in neutral/park. No codes have returned.
Ideas?
Old Oct 14, 2009 | 02:37 PM
Restricted Cat?
Old Oct 14, 2009 | 03:32 PM
IcantDo55's Avatar
Originally Posted by chibiblacksheep
Restricted Cat?
Maybe.
Old Oct 14, 2009 | 03:42 PM
If your friend wants to fix this problem, this is the BEST way to fix it. (plus other issues)
https://www.zzperformance.com/grand_...=551&catid=110
he would want the 2.5" bolt-in downpipe with high-flow cat + gaskets. (preferably 305 stainless, but that's extra $$)
Old Oct 14, 2009 | 09:29 PM
IcantDo55's Avatar
1st I'll unbolt the exhaust and see if it helps. I'll report back.
Old Oct 16, 2009 | 01:16 PM
Steven73's Avatar
I would check coil Packs.... I had some what same issiu with onlyu 65 000kms I turned onto highway at like 3500rpm it it would hesitate kinda BUCK then shift. (this was only if i reached 3500/4000rpm... If i kept it under that would drive Fine and shift
