Car sounds like it has a 2step?
Working on a friends 3.8L 2000 and it won't rev above 4K rpm sounds like its on a 2 step. On the road or in neutral no difference.
Car has 200K on it and little to no matience, and as far as I know its been like this for 10-20K miles. There a common cause for this? Car does have a CEL on but until I fix the cooling system problem in my other thread I can't bring it anywhere to get codes read. |
well in nuteral/park the comp limits it at 4 grand if i remember right... and if it does it in drive it may be in limp mod becuase of the problem mentioned in your other thread
Originally Posted by Budsjlm
(Post 168749)
It will do it in neutral/park or on the road while driving. This sounds like an ignition miss and being the CEL is flashing confirms its missing. |
Ignition Coil maybe?
So I have removed the upper intake and check it out, replaced gaskets and cleaked out EGR, replaced wires and plugs, removed and cleans the coils and module under them.
Than I cleared the codes and the car still does the same thing @ about 4K it just hits a wall and wont rev any higher, while driving or in neutral/park. No codes have returned. Ideas? |
Restricted Cat?
Originally Posted by chibiblacksheep
(Post 169463)
Restricted Cat?
If your friend wants to fix this problem, this is the BEST way to fix it. (plus other issues)
https://www.zzperformance.com/grand_...=551&catid=110 he would want the 2.5" bolt-in downpipe with high-flow cat + gaskets. (preferably 305 stainless, but that's extra $$) |
(Post 169475)
I would check coil Packs.... I had some what same issiu with onlyu 65 000kms I turned onto highway at like 3500rpm it it would hesitate kinda BUCK then shift. (this was only if i reached 3500/4000rpm... If i kept it under that would drive Fine and shift
