Car problems
![Confused](https://montecarloforum.com/forum/images/smilies/confused.gif)
If you need anymore information let me know
Also put regular in your car. There is no need to throw your money away.
Thanks for the help by the way,I will keep updating what happens when I can
but i would do the basics first do a tune up and go from there it is easy to diagnose from there. also rule out old plugs and wires also new filters every where. then check the sensors chibi mentioned then go from there. it might be a off sensor to a bad cat or poor fuel pressure from the fuel pump.
I've been doing some reading, my issue is similar. I am waiting on new parts.
MAF/IAC, so far i've changed spark plugs, fuel filter, pcv, and wires.
If the MAF and IAC don't get rid of the issue i'll be buying a new Crank Position Sensor, a good thread from clubgp leads to believe it may also be the culprit. Good luck!
6th Gen ('00-'05): Multiple problems, fed up with car
02montecSS
09-23-2014 05:27 PM
willeatforfood
11-23-2008 03:19 PM
splendidkiller
10-30-2007 07:24 PM
