car problems
Old Sep 9, 2010 | 11:46 AM
shamgodlou's Avatar
Default car problems
My car was driving fine then all of sudden when I was driving, it started hesitating to go to the first gear. Then it hesitated again, then it just died. I looked under the car and there was fluid leaking out. Now the car powers on (lights windows etc) but it doesnt turnover. Anybody have any guesses as to what went wrong. Please dont tell me its the transmission!
Old Sep 9, 2010 | 12:02 PM
Sparky-88's Avatar
Need more info. Most important question: What type of fluid is leaking - oil or trans fluid (reddish color). Can you describe the 'hesitating to go to the first gear' a little more? Trouble moving forward from a stand-still? Trouble downshifting to first?
Old Sep 9, 2010 | 12:11 PM
shamgodlou's Avatar
Well the car doesnt turn on now but when i drove it when i pressed on the accelerator it would not speed up it would just kind of stall. As far as fluid goes it all leaked out so i couldnt see the color but the fluid leaked from the left front side of the car if that helps
Old Sep 9, 2010 | 12:25 PM
Sparky-88's Avatar
How about checking oil and trans dip sticks for fluid level. That will confirm which fluid got dumped (assuming they were at proper levels to begin with).
Old Sep 10, 2010 | 08:44 PM
lucian*91's Avatar
so did it drive fine then just hit like that?
Old Sep 18, 2010 | 12:23 PM
shamgodlou's Avatar
yes thats pretty much what happened
Old Sep 18, 2010 | 12:29 PM
GrandPaDave's Avatar
Fuel filter?
Old Sep 18, 2010 | 04:21 PM
shamgodlou's Avatar
Originally Posted by SolaraSlayer
Fuel filter?
How do i check and see if somethings wrong with the fuel filter?
Old Sep 18, 2010 | 05:42 PM
Beautikill.2000monte's Avatar
drop the gas tank
Old Sep 19, 2010 | 02:07 AM
labnjab's Avatar
Depends on what year. The newer monte's (5th and 6th gens i think) its located on the frame rail just in front of the left rear tire.
Since it turns over I'm thinking you may have blown a fuel line. Have someone cycle the key off and on and look underneath. If its a blown fuel line you'll see gas pouring out as they cycle the key
