ignition problems with car starter installed
Old Oct 30, 2007 | 08:15 AM
splendidkiller's Avatar
Default ignition problems with car starter installed
i have a 2001 monte carlo ls and i was having the passlock problems where it wouldn't let me start the car for about ten minutes and this would happen once about every 30 or 40 starts. so i had a remote start installed to bypass the passlock system and now that it's gettin a bit cold out it's acting really weird. i use the remote start to start it in the mornin about ten minutes before i go out in order for it to warm up inside and what not, but when i get inside and put the key in, turn it to on, and press the brake, it shuts off and acts like the passlock problem as described above. the only difference is that the traction control off light comes on and it says callibration error on the radio. i can take the key out and start the car with the remote, but i have to wait until the inside is warmed up enough for me to use the key. after it is warmed up enough inside it has no problems at all. it has taken longer then 10 minutes once so it is not the passlock system i don't think. does anyone know how to fix this?
Old Oct 30, 2007 | 01:03 PM
couch's Avatar
Default RE: ignition problems with car starter installed
i'd take it back to where u got your remote starter installed. blame them
Old Oct 30, 2007 | 02:04 PM
kweef's Avatar
yah id go back and blame them...c what they do, u never know they mite just fix it no questions ask
Old Oct 30, 2007 | 04:21 PM
i called them today and they said that it is indeed the ignition and the passlock system. they said that there are resistors in the ignition that may change value if they are cold or hot and it sounds like the ignition needs to be replaced with a new passlock system
Old Oct 30, 2007 | 07:24 PM
kweef's Avatar
what did they say about fixin it?
rmorman
Oct 24, 2013 06:32 PM
bhines47
Jun 19, 2012 08:57 PM
Rell
30
Mar 25, 2010 11:57 PM
Mike95MonteLS
Sep 25, 2006 01:36 PM
vampy1274
Aug 2, 2005 09:55 PM
