6th Gen ('00-'05): Can't get radiator in
Old Nov 9, 2021 | 03:12 PM
Metalunicorn00's Avatar
Default Can't get radiator in
So I'm trying to replace the radiator, but when I went to put it in, I noticed that this piece was bent up. What's the best way to bend it back without damaging anything?
also, should I replace the AC condenser as well?
Old Nov 13, 2021 | 11:51 AM
Are you talking the lower radiator core support? If it is truly bent, it would be wise to bend it back. Hard for me to tell what is bent in that pic.
Old Nov 13, 2021 | 03:04 PM
Agreed, its very hard to tell what is bent in the pic as it looks pretty normal from this angle. The method of straightening would depend on where, how much, and how localized the bend is (IE did it hit a rock that only crinkled a few inches way out of whack or did it hit a parking block that slightly bent the whole thing).
Old Nov 14, 2021 | 10:11 PM
They make cleaners for the a/c condenser. If it is still functioning, keep it. Now would be the perfect time to do an actual thorough cleaning as it does look like the air flow is restricted. You Tube it...
Jerry Musick
May 15, 2021 08:00 AM
Darius Lovehall
Jul 3, 2014 02:58 AM
WreckedMonteCarlo
May 20, 2011 09:04 PM
tj4ndirish
Dec 9, 2010 06:00 AM
99MonteZ34
May 20, 2010 03:04 PM
