Radiator Help, Quick Please
Old Dec 5, 2010 | 09:59 PM
tj4ndirish's Avatar
Default Radiator Help, Quick Please
Ok, long story short, I ran a screwdriver through my radiator. In looking for a new one, there is the option of with or without bevel washer to cooling fittings. What does that mean? How do I tell which I have? Mine has the cooling lines that have to be bolted to the radiator.
I'm finding them on ebay and another website, automotix.....anyone else know of where I can get one quickly and cheaply?
Thanks.
Old Dec 9, 2010 | 06:00 AM
rgant_19's Avatar
I had to bite the bullet and buy another radiator "New". I was advised not to buy a used radiator because of the wear and usage it has and do not know when it will fail. So I bought mines off of autozone.com which was $170. I know that's a lot but I don't have no overheating nor not having heat problem. As far as the the fittings, I just change the radiator instead of choosing which fitting to buy. When (or if you do it yourself) you change your radiator, make SURE you replaced all the bolts and screws back how it was before the removal of the original radiator.
Btw, don't buy off of ebay for cheap radiators, they are not american made and will malfunction on you. Watch what you buy! Do your homework on what radiator to buy and where from...
Jerry Musick
May 15, 2021 08:00 AM
killerBee
Jul 1, 2018 02:14 PM
Sparky-88
Feb 27, 2011 08:55 AM
jay26
Feb 7, 2008 05:23 AM
