6th Gen ('00-'05): A/c fan works radar or fan dosent work
Old Jun 6, 2020 | 09:21 PM
Mgw2k20's Avatar
Default A/c fan works radiator fan dosent work
Help please. I have a 01 ss with 140000k miles on it. It runs about 3 quarters of the way to the red line. If your standing over it looking at the fans the left side will run. I believe that is the a/c fan the right fan I believe is the fan to cool the engine and coolant. I may be wrong and thats ok as well. I can't get the fan to run on the right side no matter what I do with the ac or heat or windshield defrosters. I have been using the heat to offset this problem but with temperatures rising it's becoming critical to fix. Don't have much money to have it in a garage. There are no puddles of coolant anywhere but I had to fill coolant for the 2nd time in 2 months. Fan squealing sometimes when it kicks on on the left side. Right side dosent kick on what do I do?
Old Jun 7, 2020 | 04:50 PM
Steelbizkit's Avatar
Fans are a 2 speed fan style, they both run at same speed at same time, low speed is at lower temps (180 to 200ish if I remember right) and high speed is at 200+ or when a/c line pressure kicks it on.
If one fan won't kick on it needs replaced.
Murray Fan Assembly same I'm running in my 03.
Old Jun 7, 2020 | 05:01 PM
Mgw2k20's Avatar
Actually it's the tempeture sensor the fan runs if I wire it directly to batterey so I have a project next weekend. Had a buddy check it out. I could still be wrong but I'll let u know how that goes
Old May 5, 2021 | 06:11 PM
Triple3D's Avatar
Been almost a year what happened?
claydoh
Jul 8, 2019 07:26 PM
thewhitestcarlouknow
May 6, 2014 08:48 PM
Ryans93'
Jul 11, 2012 11:13 AM
1996Monte_Carlo
Jun 17, 2011 02:05 PM
Dade Chevy
Jul 8, 2009 05:09 PM
