Secondary cooling fan question
Old Jul 11, 2012 | 08:26 AM
Ryans93''s Avatar
Default Secondary cooling fan question
At what point does the secondary cooling fan start up? I have not seen it kick in yet and I have no power going to it at the motor itself. Just wondering if they dont come on till the engine reaches a higher temperture than normal. Anyone know how its set up to run? Primary comes on just fine. Thanks!
Old Jul 11, 2012 | 08:49 AM
z34phoenix's Avatar
yes the second fan does activate on a higher temp. somewhere around 20* higher. are you having over heating problems? you could always wire a relay and trigger the 2nd fan when the first comes on. i did this before i bought my tuner. with the tuner you can have the fans on at what ever temp you want.
Old Jul 11, 2012 | 09:01 AM
Ryans93''s Avatar
What controls it? PCM? It was doing some over heating with old coolant, flushed it last night and will see how it goes.
Old Jul 11, 2012 | 09:03 AM
It should turn on at 222 degrees I believe. Also it should kick on with the AC
Old Jul 11, 2012 | 11:13 AM
Ryans93''s Avatar
Thanks! I will have to run and check it out.
Chaz
Jan 26, 2014 04:54 PM
Danariel
Oct 27, 2010 11:22 PM
kingzen34
Jul 21, 2009 01:11 AM
seth_06
Dec 2, 2006 05:42 PM
