6th Gen ('00-'05): check engine cooling fan
Old Jul 8, 2019 | 01:33 AM
claydoh's Avatar
Default check engine cooling fan
got a check engine light on, autozone checked it, cooling fan 1, car is not overheating but seems fans not coming on? I checked fuses, they were ok? whats next? I don't want to replace both fan setup if I don't have to! although Rockauto has fan replacements pretty cheap? I cleaned the fan plugs with electrical cleaner too???
Old Jul 8, 2019 | 07:26 PM
I would assume you could apply 12v to the fan and see if it activates. Also check if the wiring for the fan has good ground and that the positive traces back to the fuse panel. I believe there are also relays for the fans to check.
Gary Thomas
Oct 2, 2019 08:25 PM
Dboybakr
Mar 25, 2018 12:38 PM
thewhitestcarlouknow
May 6, 2014 08:48 PM
ohiobronco
Aug 28, 2012 12:35 AM
Jon
Aug 30, 2011 07:55 AM
