BELT TENSIONER
Old Nov 22, 2008 | 07:45 PM
wnmech's Avatar
Default BELT TENSIONER
I have a 2003 M/C SS and I need to replace the water pump. It looks pretty easy except how do I loosten up the tensioner on the serpentine belt. I did not see a slot for a half inch breaker bar. Thanks
Old Nov 23, 2008 | 06:52 AM
RocknSS04's Avatar
Default RE: BELT TENSIONER
Should be a 1/2" square in the bracket of the tensioner for the breaker bar.
Old Nov 23, 2008 | 03:24 PM
wnmech's Avatar
Wayne
Thanks for the reply. I just went out into the garage and there is no square 1/2 inch breaker bar slot to relieve the tension. Any other thoughts from anyone else?
Old Nov 23, 2008 | 03:47 PM
RocknSS04's Avatar
Try putting a socket on the center of the pulley. 14 or 15mm, it looks like. Rotate the tensioner counter-clockwise on a 3.8L, clockwise on a 3.4L. Per Haynes manual.
Old Nov 23, 2008 | 05:57 PM
wnmech's Avatar
Wayne
Thats the trick it took a 15mm socket with a breaker bar. Thanks
KWJR86
Apr 8, 2012 09:30 PM
mrl390
Mar 12, 2010 10:00 PM
24_48Fan
Mar 21, 2007 10:01 AM
montejass
Sep 1, 2006 06:16 PM
montejass
Aug 7, 2006 09:32 AM
