Air position problem
Old May 4, 2019 | 10:03 AM
klima84's Avatar
Default Air position problem
Hello every one , i have problem with air position working only one position . I don’t know where is pump . Pleas help me . Chevrolet Monte Carlo 96 3,4l
Old May 5, 2019 | 12:36 AM
Are you talking about the speed for the blower motors? That you only have one speed?
Old May 5, 2019 | 03:39 AM
klima84's Avatar
I mean, the regulation of the airflow position. The fan only works on the windshield. and I can not switch to legs or other positions. I know only that it is related to the air pump, but I do not know where it is. unless I'm wrong
Old May 5, 2019 | 09:26 AM
AH. Gotcha. Unfortunately, I am not familiar with the 5th gen HVAC set up. I believe that era of GM usually controlled which vents would open and close by vacuum controls..... But outside of that, I don't know much about it. Hopefully someone else here is able to fill in some gaps.
Old May 5, 2019 | 11:46 AM
klima84's Avatar
ok thanks for the answer I will be looking at the forum further. unless you know someone who could say more about 5 gen. thank you and best regards
klima84
May 4, 2019 05:39 AM
GaJItt
Jul 31, 2015 07:42 PM
justinngpt
Jun 19, 2014 02:38 AM
Derbking7
Jul 22, 2011 06:45 PM
shovelhead pete
Feb 10, 2011 12:17 PM
