Air position problem
I mean, the regulation of the airflow position. The fan only works on the windshield. and I can not switch to legs or other positions. I know only that it is related to the air pump, but I do not know where it is. unless I'm wrong
AH. Gotcha. Unfortunately, I am not familiar with the 5th gen HVAC set up. I believe that era of GM usually controlled which vents would open and close by vacuum controls..... But outside of that, I don't know much about it. Hopefully someone else here is able to fill in some gaps.
6th Gen ('00-'05): air blowing out all vents?
GaJItt
Jul 31, 2015 07:42 PM
shovelhead pete
Feb 10, 2011 12:17 PM
