95 MC Power Window Switch
Old Nov 15, 2014 | 12:28 AM
cjnut's Avatar
Default 95 MC Power Window Switch
Ok so I believe I have a bad driver side window switch, my problem is locating one with the same pin out as OEM. ALL of the replacements have 7 pins but their is a space in the 3 row. (if that makes sense) It appears to be from a 6th Gen. Same switch different pin out. I tried to remove and replace the wires in the plug but that didn't work and searching all the yards with in 50 miles comes up empty as well. According to the dealer OEM switch is no longer available so you have to get a $90 adapter as well as the new switch, from dealer $130..
Passinger window works fine and drivers window will not go up. I have checked all the wires and everything is in very good shape. I guess I need to find an OEM window switch with matching pin out new or used.. Any help is greatly appreciated Thanx..
Old Nov 15, 2014 | 07:44 AM
Have your considered checking your area's Junk & salvage yards for a window switch (since there's no OEM one ?)
I hope one of our member's can help you...
Below is a link to check (Hope it helps) Good Luck
Car-Part.com--Used Auto Parts Market < Click
www.car-part.com/
Stebbins Auto Parts, Inc.
150 Million used auto parts instantly searchable. Shop our large selection of parts based on brand, price, description, and location. Order the part with stock .
Old Nov 16, 2014 | 01:02 AM
cjnut's Avatar
I have checked all the salvage yards within 50 miles and no luck.. Thanx for the link, come Mon I have some calling to do..
Old Nov 16, 2014 | 09:42 AM
Have you tried looking on ebay or craigslist?
Heres some from ebay..
1995 montecarlo driverside window switch | eBay <------ clicky
willie8701
Jan 15, 2008 07:49 AM
2000_BLACK_SS
Jan 15, 2007 11:07 AM
schultzy
Dec 23, 2006 11:37 PM
schultzy
Dec 22, 2006 02:36 AM
montecarlo1995
Jul 6, 2005 05:06 PM
