02 power window switch
Old Dec 22, 2006 | 02:36 AM
schultzy's Avatar
Default 02 power window switch
the up side of switch(driver side) seems to be getting less and less of a contact, needs replacing, does the door panel need to come off? I notice screw under grip, looks like it may hold top plate down. hand in cast,looking for easy way out ,,help
Old Dec 22, 2006 | 05:58 AM
04 Intimidator's Avatar
Default RE: 02 power window switch
Welcome to the forum Lee! What year Monte are you referring to as the 80's, 90's, and 00's are all different as to how you replace or fix these switches.
Old Dec 23, 2006 | 06:14 PM
schultzy's Avatar
thanks for the quick response intimidator! its a 2002 ss with all the bells and whistles. any easy solution would be helpfull,any idea what i should be paying for a switch,,again thanks lee
Old Dec 23, 2006 | 06:18 PM
hckygoalie31's Avatar
Have fun with that
I had to replace mine as well in my 2001. The top panel (the panel where the switch is located) can pop off. But you have to be VERY careful, otherwise you'll ruin the finish of the top panel.
I'd get a panel-popper to do it.
Old Dec 23, 2006 | 08:52 PM
Panal poper would be a good idea... I always use a flat blade screwdriver
Old Dec 23, 2006 | 09:33 PM
schultzy's Avatar
thanks goalie& int.for the advice, that I can handle with this %#*%^&$# cast.
Old Dec 23, 2006 | 11:37 PM
By the way...you said what should you expect to pay for the switch....
I think mine was $35.00.
chevyrider08
Apr 30, 2008 07:23 PM
willie8701
Jan 15, 2008 07:49 AM
2000_BLACK_SS
Jan 15, 2007 11:07 AM
schultzy
Dec 22, 2006 02:36 AM
montecarlo1995
Jul 6, 2005 05:06 PM
