Power window switch
Old Jan 13, 2007 | 09:10 PM
2000_BLACK_SS's Avatar
Default Power window switch
I have been fighting this problem for a while my driver side power window switch will make the window go down but it will not go back up (driver window only passenger works fine). During the summer i had this problem took the switch apart and fixed it.I dont know how but it worked when i put it back together but i think the switch is just going now so is there any where i can get one.
i have already triedthe local junk yards with no luck and cant seem to find the right thing on the internet or ebay. please help.
Old Jan 14, 2007 | 05:11 PM
2000LS's Avatar
Default RE: Power window switch
http://cgi.ebay.com/ebaymotors/2000-...QQcmdZViewItem
or just goto a dealer
Old Jan 14, 2007 | 06:20 PM
Mrrench's Avatar
check to see if you have power going thru the switch to raise the window.....
I think you might find that you have a window motor going bad
Had the same problems with my 03 grand prix
Old Jan 15, 2007 | 11:07 AM
Iknow it is not the motor because when i took the switch apart yesterday and i would press the two metal plates down the window would go right up but whenever i put it back together it would not move at all it would just be able to go down.
Thanks 2000LS i just ordered the part from that guy hopefully it will work now.
chevyrider08
Apr 30, 2008 07:23 PM
willie8701
Jan 15, 2008 07:49 AM
schultzy
Dec 23, 2006 11:37 PM
schultzy
Dec 22, 2006 02:36 AM
montecarlo1995
Jul 6, 2005 05:06 PM
