2K Monte stalls when put in gear
Problem seems to be returning..... Stalls or near stalls at idle,,,,, error code on two testers says cam sensor,,, but I put a new cam sensor on it when I did head gasket job,,,, anything can happen, new parts 'can' fail,, but what other demons can be going on, to fool the computer,,, that it thinks it is the cam sensor ,,,,,
If it's missing, and down on power, (due to age) it will definitely die when put in gear. One of the oboe tests should point you in the right direction. Could even be the wrong head gasket. h
6th Gen ('00-'05): gear set, 4th gear hub, channel plate gouged! help!
turbo monte
04-04-2013 10:01 AM
Beladona_13
10-07-2012 03:37 PM
Boomer
05-22-2011 08:26 PM
blownincome
03-15-2010 10:43 PM
