01 monte ss idle flair then stalls
Old Mar 9, 2010 | 04:28 AM
blownincome's Avatar
Default 01 monte ss idle flair then stalls
Any one seen this one before??? Car runs normal I mean text book then when sitting there idling stumbles has a idle flair then stalls when I try to restart it will only start if I set the pedal half way. when it does it stumbles chokes spews black smoke then diesels to a stall again it did have a code for a MAF (high resistance) replaced, as well as a new IAC replaced for this symptom (No codes now) just unpredictable so as of rite now no misfires logged no codes ....Any ideas??? Thanks Bob
Old Mar 9, 2010 | 05:37 AM
Hi `Bob, and Welcome to the MCF
Sorry to read that you are having a problem with
your Monte Carlo.
1. How many miles on your Monte
Please check back on your thread question/problem, and
hopefully one of our expert tech member's will
be able to assist, and give you some advice
on resolving your issues.
Who replaced the MAF ? How long ago was it replaced ?
Have you checked with them on your problem?
Good Luck 4-Sure.
Old Mar 9, 2010 | 07:18 AM
Wilco's Avatar
You may find this thread interesting: http://www.justanswer.com/questions/...-over-no-spark
Check it out and then inspect your car's wiring around the A/C accumulator to see if there's any damage to any of the wires.
Old Mar 9, 2010 | 12:02 PM
Default Fix
turns out its a defective MAF replaced with another new one Fixed!!! Go Figure
Old Mar 9, 2010 | 12:05 PM
Talking
your Monte Carlo.
Good Luck 4-Sure.
See Just Above New MAF NG Replaced Fixed!!
Old Mar 15, 2010 | 10:43 PM
Justin Knight's Avatar
Any help I can give on tech questions I would love to help I'm a licenced tech from Ontario and see a lot of 3.8litre engines so I have a vast repair history. Please reply.
Tgregor91
Aug 3, 2015 08:44 PM
Skittlez87
Jan 21, 2014 09:56 PM
mooke46
Oct 2, 2010 04:39 PM
concrete
Sep 9, 2010 03:55 PM
rockieg00
Mar 7, 2010 10:33 AM
