2006 Monte Carlo Trouble
I have a 2006 Monte Carlo with an Intermittent No Start Problem cranks fine
I get DTC's
PO102 Mass Air Circuit low
P1516 Electronic Throttle Mod VS TP Performance
P1682 Ignition Switch Fault
P2078 IMT Valve Sensor Circuit High
after working on it and getting it to start I clear the codes and get all the codes except the P2078, I cant figure it out, it just suddenly started on thursday.
I get DTC's
ok so after a weeks worth of minimal time diagnosing my monte I have found my 2 problems 1 the battery is too small for my car causing intermittent voltage spikes to sensors and 2 the one sensor it did fry the TPS 1 and 2 Sensor in the Throttle body new parts tomorrow wish me luck on the repair also anyone else have this problem and does anyone know how to relearn the throttle body
Z34 in the Couve
01-28-2009 03:18 PM
