2006 Monte Carlo Trouble
Old Aug 9, 2010 | 03:35 AM
06Monte's Avatar
Default 2006 Monte Carlo Trouble
I have a 2006 Monte Carlo with an Intermittent No Start Problem cranks fine
I get DTC's
PO102 Mass Air Circuit low
P1516 Electronic Throttle Mod VS TP Performance
P1682 Ignition Switch Fault
P2078 IMT Valve Sensor Circuit High
after working on it and getting it to start I clear the codes and get all the codes except the P2078, I cant figure it out, it just suddenly started on thursday.
Old Aug 9, 2010 | 10:30 AM
RickAKATed10's Avatar
Photobucket
Not sure, hope some one can help though.
Old Aug 10, 2010 | 05:32 AM
06Monte's Avatar
Default Damn
Now my 06 wont even start only crank no spark and no DTC change I give in I'm gonna pay the dealer the $120 Diag fee and let my Extended Warranty pick up the tab
Old Aug 10, 2010 | 10:30 AM
Photobucket
Yeah, if you're warrantied you have to take it to the dealer. There's no reason not to.
Old Aug 14, 2010 | 06:15 AM
06Monte's Avatar
ok so after a weeks worth of minimal time diagnosing my monte I have found my 2 problems 1 the battery is too small for my car causing intermittent voltage spikes to sensors and 2 the one sensor it did fry the TPS 1 and 2 Sensor in the Throttle body new parts tomorrow wish me luck on the repair also anyone else have this problem and does anyone know how to relearn the throttle body
Old Aug 16, 2010 | 12:20 PM
Photobucket
Good luck!
Old Aug 17, 2010 | 06:54 PM
kingreyna's Avatar
Sorry to hear about your Monte. What engine is it?
Slugger088
Sep 9, 2011 07:24 AM
bwill314
May 4, 2009 10:41 AM
bwill314
Mar 25, 2009 04:45 PM
Z34 in the Couve
Jan 28, 2009 03:18 PM
winterkage
Jan 20, 2009 12:39 PM
