7th Gen ('06-'07): 2006 monte carlo flasher location
Old Sep 30, 2018 | 03:21 PM
Rebel423's Avatar
Default 2006 monte carlo flasher location
I have a 2006 monte carlo 2dr 6cyl. Passenger side front turn signal does not work, bulb lights up but does not flash, new bulbs do not flash. Put a new turn signal switch in but no difference. I can not find anywhere online that will show me where the flasher relay is. The fuses for the turn signals are both good aswell
Old Oct 24, 2021 | 05:02 PM
Lee Spencer's Avatar
I'll bump this thread because I have the same question. I'm dealing with hyperflash and I want to know if I can find a replacement relay that compensates for LED's.
I realized while trying to find the relay that the clicking I was looking for was actually coming through the stereo like a simulated relay sound! Is there a relay at all in these later Monte's?
Old Oct 25, 2021 | 09:06 AM
Isnt it built into the hazzard switch? I believe @The_Maniac has solutions for this...
Old Oct 25, 2021 | 08:36 PM
Agree, believe the Admin. "Maniac" solved your hyper-flash issue. Use the search bar below your forum user name and type in "FULL LED LIGHTS AND NO HYPER FLASH"
Old Oct 25, 2021 | 10:18 PM
So, the 00-05 Monte the Flasher Module is also the Hazard switch. In the 06-07 Monte, is not the same. It looks like the command to actually "blink" the turn signals is managed by the BCM in these years of the car. Sadly, I lack any experience with the 06-07 model years. The quote below is direct from the shop manual.
The BCM controls the vehicle turn signals based on inputs from the turn signal/multifunction switch. With the turn signal/multifunction switch in the left turn position, a ground path is provided on the left turn signal switch signal circuit, indicating a left turn signal request. With the turn signal/multifunction switch in the right turn position, a ground path is provided on the right turn signal switch signal circuit, indicating a right turn signal request. When the specific request is seen, the BCM will pulse the respective turn signal lamp supply voltage circuits, illuminating the turn signal lamps.When a turn signal request is seen by the BCM, a serial data message is sent to the instrument panel cluster (IPC) requesting the respective turn signal indicator be pulsed.
Attached is the shop manual diagnostic pages for this issue in a 2006 Monte.
Old Oct 25, 2021 | 10:22 PM
I have the ultimate hyper flash solution for 2000-2005 montes/impalas, as well as 99-05 grand ams and a few other GM cars from this era. I sell modded flasher modules (aka the hazard switch).
If you are dealing with a 00-05 monte (and based on your profile pic, looks like you are), the clicking you hear is not simulated, it is not coming from the radio. I can guarantee, the sound you are hearing is the relay in the flasher module.
Here is the thread to my modded flashers I sell. I have some now all set and ready to ship. $40 via paypal and I will have them with USPS ASAP.
https://montecarloforum.com/forum/pr...signals-62250/
if you want to do the mod yourself, here is the info (my original "test bed" was my Grand Am, same flasher module):
https://montecarloforum.com/forum/fw...signals-61550/
And here is when I finally did everything with my Monte:
https://montecarloforum.com/forum/pa...r-flash-62573/
SteveQ
Oct 3, 2019 01:44 PM
Barbie
Jun 17, 2019 09:09 PM
ktagrnma3
Aug 18, 2015 07:41 PM
gdogg090
Jun 25, 2011 03:16 PM
bigmichaelcool
Feb 9, 2008 07:41 PM
