turn signal issue
Old Jun 20, 2011 | 05:02 PM
gdogg090's Avatar
Default turn signal issue
My turn signals have started to make a loud noise an blink all weird I stopped to pick up a new flasher but the guys at autozone say the car does not have them ? Any help at all would be much appericated
Old Jun 20, 2011 | 05:20 PM
shineman08's Avatar
Im guessing a bulb went/is on the way out. They should have the turn signal bulb there, otherwise try a different auto parts store.
Old Jun 20, 2011 | 05:44 PM
Coors's Avatar
Yes, my flasher on my 03 monte stops every once in a while and my turn signals don't work. I put on my hazards for a second and then the turn signals will work. I also have tried to find a new flasher but all the auto parts stores say they don't have one or a number. Anyone know where to get one? All of my bulbs are fine.
Old Jun 23, 2011 | 09:26 PM
kc2kth's Avatar
Default Hazard Switch
The turn signal relay is integrated into the hazard switch. Have to pop the dash, but it looks pretty simple. I haven't tackled mine yet, but here is the part I needed for my 2003. I believe this is what you are describing.
RockAuto Parts Catalog
Old Jun 24, 2011 | 08:59 PM
gdogg090's Avatar
thanks guys for all your help yall are life an money savers lol
Old Jun 25, 2011 | 03:16 PM
model16's Avatar
If you move the stick up and down will they flash? My step dads 02 impala had this problem, pretty sure it was the relay problem as mentioned above, they had to do a bunch of stuff in the dash by the steering wheel if I remember right..
If its blinking really quick check out the bulbs, one might be dead..Also check out the connection..I had a bulb once that I though was dead, went to check the connection and some how one of the metal prongs came out of place.
Little Cheese
Feb 15, 2015 06:11 PM
Jeherr
Oct 6, 2012 05:08 PM
DCWZen
Sep 12, 2011 08:44 AM
bikerboyzzky
Aug 9, 2011 12:00 PM
Lee55
Jun 9, 2006 09:20 AM
