Opinion Needed: 2003 Monte Carlo security re-learn
Old Jul 6, 2019 | 06:09 PM
LeeBo Freeman's Avatar
Default 2003 Monte Carlo security re-learn
I just replaced a lock cylinder and the 3 x 10 min relearn doesn’t work. The car won’t start but the security light is not blinking. HELP NEEDED
Old Jul 8, 2019 | 07:28 PM
What prompted the need to change the lock cylinder?
Assuming the chip for the lock cylinder is plugged in all the way and no wiring issues, the only way to fix this is the security relearn. Attached is a document I keep on this (pulled from the GM shop book). It is important to watch that after 10 minutes the security indicator stops and that you never remove the key from the cylinder.
File Type: docx
Old Jul 12, 2019 | 01:13 PM
HKnux5112's Avatar
I waited 15 minutes for mine. Started on the 3rd try. Never took the key out.
Bwill414
Oct 5, 2019 08:56 AM
Ted Kasiewicz
Jun 29, 2019 03:56 PM
Jay s
Nov 11, 2016 01:00 AM
BigEd
Oct 6, 2014 02:28 AM
keghead40
Jan 7, 2007 03:08 AM
