Opinion Needed: 2003 Monte Carlo security re-learn
What prompted the need to change the lock cylinder?
Assuming the chip for the lock cylinder is plugged in all the way and no wiring issues, the only way to fix this is the security relearn. Attached is a document I keep on this (pulled from the GM shop book). It is important to watch that after 10 minutes the security indicator stops and that you never remove the key from the cylinder.
6th Gen ('00-'05): Security light won't stop flashing
Bwill414
Oct 5, 2019 08:56 AM
Ted Kasiewicz
Jun 29, 2019 03:56 PM
