2002 Monte Carlo
Old Oct 12, 2014 | 09:24 PM
02 Monte Carlo's Avatar
Default 2002 Monte Carlo
I have a 02 Monte Carlo SS and my problem is as follows:
When I start the car , it will go into all gears for only a moment or two, then nothing. If it sets for awhile, it will do the same. I don't know if it is a transmission problem or torque converter problem. Please advise.
Thanks
Old Oct 13, 2014 | 05:36 AM
Sorry to read about your problem
How many miles on your Monte Carlo ?
Do you have any modifications ?
Have you ever had your transmission serviced ? Fluid changed, filter ? etc ?
Have you checked your auto trans fluid level ?
Please advise to help our tech member's help you!
Good Luck
Old Oct 13, 2014 | 03:41 PM
Default 02 Monte Carlo
I have 156000 miles on the car. I have not changed the trans fluid in a while, but the fluid level appears okay. I did add some Lucas trans fix . It was jerking before it stopped working.
Old Oct 13, 2014 | 07:20 PM
owens91's Avatar
maybe if you can get to a local auto parts store and see if they can scan the car, sometimes a transmission code will pop up
Unikardo
Oct 21, 2014 09:58 PM
Dispatcher7168
Jul 16, 2013 02:50 PM
wheels
Aug 13, 2007 08:06 PM
Nasal
Sep 23, 2006 11:58 AM
DuluthMonte
Mar 5, 2006 05:46 PM
