6th Gen ('00-'05): 2000 monte sputtering out
Old Jun 5, 2015 | 10:53 PM
Dj_bosse's Avatar
Default 2000 monte sputtering out
I recently posted about my Monte with 209,000 miles sputtering when I started it and then stalling out around 50 mph. I replaced the spark plugs and wires and now it's sputtering so bad that it dies if I don't give it gas. I think it's either the fuel pump or fuel pressure regulator. I don't know what maintenance has been done prior to me purchasing the car other than the fuel filter. Is there any way I can check the fuel pressure regulator or fuel pump? Thanks in advance.
Old Sep 25, 2015 | 11:45 AM
Storman1's Avatar
check your oil pressure sending unit for leaks
Old Sep 25, 2015 | 10:39 PM
Budsjlm's Avatar
When it gwts in a spuddering fit or dies on you like that again unplug the mass air flow sensor, if it run and drives fine replace it becuase it's junk
Dj_bosse
May 23, 2015 09:26 PM
Watty
Jan 1, 2015 06:47 AM
HPNOTIQracing
Jan 27, 2011 08:50 AM
Pjw350
Mar 19, 2009 10:42 PM
ajsbengals
Apr 12, 2008 09:51 PM
