Sputtering
Old Apr 12, 2008 | 05:39 PM
ajsbengals's Avatar
Default Sputtering
Hey guys,
I had posted something similair on this before, but i just had it in the shop and still have the same problem. This is completely random, sometimes the car will do it, sometimes it wont. When i get to 2000-3000 RPM I can see the RPM'S drop a little and then i cant accelerate at all, the car will sputter and kick back very hard. I had it into my local GM dealers shop and they took the entire tranny apart and said it looks fine, no issues. They then sent the car back to me saying that my intake is making the car run lean (bunch of bs). but just to make sure i threw the old intake back on and still have the same issue. anyone ran into this before and have any opinions.
Tony
Old Apr 12, 2008 | 06:45 PM
RickCoMatic's Avatar
Default RE: Sputtering
No "Check Engine" Light coming on when this is happening?
Not even blinking?
Old Apr 12, 2008 | 06:48 PM
ajsbengals's Avatar
yes, it doesnt stay on, however when it starts to sputter, if i dont let off the gas for a few seconds it does blink. after a minute or so of normal driving though it goes right back off.
Old Apr 12, 2008 | 08:19 PM
rysZ34's Avatar
In your owner's manual, it says that if the light blinks your vehicle is running lean.
Old Apr 12, 2008 | 08:52 PM
ajsbengals's Avatar
which is why i put on the original intake, the original stock intake. nothing happened. same problem, and i left it on there for a little over a week.
Old Apr 12, 2008 | 09:51 PM
Farfig's Avatar
Clogged fuel filter. Dying fuel pump. Thats the first thing that I think of. If its intermitten like you say, does it do it when the engine is cold, warm or hot?
When my fuel pump was dying it would only do it if the engine was hot, than sat for alittle bit, enough for it to cool down to about half temp, then on restart it would chug between 2000-3300 rpm's. Finally got bad enough that it was stalling out the engine. Try letting your engine run for about 10-15 minutes at idle, and see if it gets a rough idle. Might even stall out.
SpartanDawgs
Apr 4, 2015 07:07 PM
Watty
Jan 1, 2015 06:47 AM
Jamie
16
Jul 18, 2011 07:42 PM
HPNOTIQracing
Jan 27, 2011 08:50 AM
Pjw350
Mar 19, 2009 10:42 PM
