05 gone crazy electrical
Old Apr 10, 2010 | 04:11 PM
montego's Avatar
Default 05 gone crazy electrical
just this morning i started the old monte just fine and started driving her to work. i tryed to turn up the radio and founds thet none of my radio buttons on the wheel worked. then i noticed a ding that happend every 40 seconds or so. i parked it and went to get some things done. when i came back to it i cheacked the fuses behind the drivers door and then nocticed a relay clicking from the pass side and my temp and tach gauge were pulsing. i found the "back up LP relay" clicking right along witht the pulsing so i took it out and am charging the battery because it is dead . if all the sounds crazy enough the tach and the speedo are pulsing now. it is less frequing about every minute and 20 seconds i dont have any idea what could be going on. all this is heppening when the key is not in the car. any help or suggetions would be appreciated. thanks
Old Apr 10, 2010 | 08:42 PM
Enzo354's Avatar
STILL SLOW
Try unhooking the battery and hooking it back up. Worth a shot.
Old Apr 11, 2010 | 06:32 PM
try to tighten the terminal?? that could definatly be it.(loose terminal)
Old Apr 11, 2010 | 09:27 PM
monte07's Avatar
first clean and check the terminals to the battery. also have the battery checked as well after you clean and tighten the terminals. second check the harness to the main electrical controll mod that is under the hood see if there tight as well. after that it might need a new ground some were
Old Apr 13, 2010 | 04:30 PM
aussiek2000's Avatar
I bad BCM could also cause these issues.
mwjames
Dec 25, 2013 08:27 PM
Aug 12, 2012 09:27 AM
oh3monteSS
Jan 23, 2012 11:27 AM
buckzilla
Sep 4, 2006 11:56 AM
roadshoptuner
Aug 4, 2006 07:32 PM
